cd changer will not eject
Old 02-22-2010, 01:56 PM
Jalife's Avatar
Default cd changer will not eject
New to the form. And my first post is a question.....
The cd changer in my ML 320 will not eject the CD case. The eject button in the trunk, only blinks when selected. Any one ever experience this problem?
Old 02-22-2010, 03:10 PM
what i do that usually works is bang on the magazine with your fingers as you pressing the button. keep trying and eventually it comes out. or sometimes a disk gets jammed and it wont pull back into the magazine so you sometimes operate the cd changer and play the cds and switch from disk to disk and retry ejecting the magazine. then if none of those things work youll need to get inthere with something and try to push the disk into the magazine and sonetimes youll have luck.
Old 02-25-2010, 10:22 AM
mbz connexion's Avatar
Like he said above.
You can look into the changer and see if a disc is caught between the magazine and drive system.
Old 02-27-2010, 11:03 AM
MB-TECH-38's Avatar
Default cd's
don't have any other trick to get CD out but , if you do get it out MB player's do not work well with home made CD's just my 2 cents here
Jerry
Old 02-27-2010, 11:14 AM
I usually remove the player, take off the cover and spin the large wheel on the underside of the player.
I don't know what causes the jamb but once the CD is removed the player usually works good again.
mackfisherman2
02-09-2011 08:13 PM
hally
07-12-2009 07:39 AM
lgonzalezl
05-26-2006 05:36 PM
slpman
02-27-2006 12:04 AM
Quick Reply: cd changer will not eject
