ABS light staying on
Old Nov 1, 2009 | 05:08 AM
watty1962's Avatar
Cool ABS light staying on
Hi all, new to site, 1988 300D, ABS light problem I have changed pads but light comes on within a minute or two occasionally the brakes feel like they are grinding or sticking anyone got any suggestions ?
Any help appreciated.
Thanks.
Old Nov 1, 2009 | 10:05 PM
saienni ml350's Avatar
hey, this happened to my 2001 BMW x5 alot and it was actually because the aldenader needed to be replaced, they said it was the cars way in saying that something was wrong so by your light always coming on there might be another problem that your not aware of. hope this helps
Old Nov 15, 2009 | 01:31 PM
S600moneypit's Avatar
it sounds like you have a abs sensor problem or a abs ring problem. it show up after driving because thats when it senses there is something wrong. check you senors and rings for any damage and the ohms like previously posted. they should all ohm out the same if one is different that is the bad one
Old Dec 11, 2009 | 06:22 AM
vavesealtef's Avatar
Default ABS light staying on
ok good cuz my light never goes on and my abs always goes on i thought it was broken there for a sec
Old Oct 17, 2010 | 08:31 PM
sweet fa's Avatar
Default ABS and ESP light on after changing rotors and brakes
Hey all,
I just changed the rotors and pads and sensor on my 2005 C230 Kompressor, all went well and brakes feel good but ABS light comes on now and again. Any suggestions?
Old Oct 30, 2010 | 01:57 AM
bill_horne's Avatar
In my '85 300SD, the ABS light is the first indication of low battery or alternator failure. However, I have also learned that it may indicate that a front hub has been mounted too loosely following brake work.
kennynole
Dec 31, 2015 10:13 AM
paul vp uk
Apr 22, 2015 06:32 AM
al_in_nyc
Jun 19, 2008 12:29 PM
fay3131
Jun 17, 2006 02:01 AM
al_in_nyc
Mar 29, 2005 02:00 PM
