Idle Speed Setting on Stromberg 175CD carb
Old Nov 3, 2007 | 04:35 AM
col 190's Avatar
Default Idle Speed Setting on Stromberg 175CD carb
Hi
I'm trying to adjust the fast and slow idle speeds on a 1979 w123 230 (115 engine). There are 2 bolts to screw in/out which are next to eachother to adjust this (I think)but when I turn them it makes very little difference to the idle speed. I think the one on the left is the fast idle and right is normal idle. I'm concernd that I can't adjust the normal idle below about 975 rpm (I thing 850 is what I am aiming for). Am I turning the correct screws? If so what could be causing it to not let me go lower than 975 rpm?
Any help would be fantastic.
Colin
Old Nov 4, 2007 | 08:07 AM
Shan's Avatar
Default RE: Idle Speed Setting on Stromberg 175CD carb
The shorter of the 2 bolts is the fast idle control.
Old Nov 6, 2007 | 12:00 AM
col 190's Avatar
Thanks Shan.
I still need to work out what is causing the idle screw to bottom out ... will do that tomorrow.
Colin
Old Nov 8, 2007 | 02:50 AM
Shan's Avatar
You may need to check on the vacuum regulator adjusting bolt if your car is fitted with a/c. There is a link from the accelarator lever to it to control the idle speed.
There is also a short lever linkage that controls the throttle setting. You will find it just under the choke. Its length is also crucial to idle speed setting.
I have a print version of the workshop manual. A few pages are devoted to Stromberg 175 CDT. If youthink that could help, please e-mail me: shanvks@hotmail.com.
Shan.
mbz300sdl
Oct 26, 2023 09:51 AM
col190
Mar 21, 2008 06:10 AM
Skipper1
Feb 4, 2008 11:13 AM
Blue72
Sep 10, 2006 08:53 PM
Shan
Jun 25, 2004 07:05 AM
